Hello All!
I have an ASUS PB298Q Ultra-wide monitor connected to my XFX AMD Radeon R7 265 Core Edition video card.
When I originally setup (installed video card, drivers, etc.) I was using an HDMI cable and I was getting a resolution of 2560 x 1080 (the maximum supported by the monitor).
I recently purchased a DVI Male Digital Dual-Link Cable and used tried using it instead of the HDMI. I shut down my computer and when I restarted the resolution was only 1920 x 1080 and this was the maximum I could set it to. Both Windows and AMD Catalyst Control Center indicated that this is the max resolution at the maximum frequency of 60 Hz.
I have been reading the monitor specs and manuals, etc. and nowhere does it say that the resolution for the DVI connector is less than HDMI.
Is this normal or should I be getting the same resolution as the HDMI cable? If it's not normal can anyone tell me how I might go about fixing the issue?
Thank you,
Jan
P.S. The XFX video card has two DVI cable outputs, a red one and a "normal colored" one. and I am currently using the red output.What is the difference between the two and could this be the problem?
Thank you,
Jan
