Monitor : no built in speakers
what i think you mean is:
i am buying a computer monitor without speakers but i want sound to come from the computer. what options do i have?
first you need to figure out what you will be using the speakers for. if you plan on using them for basic windows sounds, youtube or similar activities then you might be able to get away with a cheap $50 soundsystem and be happy. if you want something a bit more serious then i know logitech makes a few nice 5.1 surround sound systems. if you want to get even more serious then you're looking at a receiver and home theatre speakers.
if your computer motherboard has a built in soundcard (does it have speaker 3.5mm plugs on the back?) then youc an connect directly up to it with computer speakers. if you do not then you will need to buy a sound card and plug into that. in case you already have a sound card, use it instead of any motherboard connections.
home theatre speakers and receivers connect up to computers differently. usually this is via hdmi or spdif. however, i doubt this is the solution you want or need as even entry level products in this area might exceed your budget.
