Long post ahead. Please read fully! Thanks for you patience.
Just recently bought a desktop that’s less than 2 months old and has been running flawlessly until Monday eve. I was playing it for a couple hrs and got off around 5. I completely shut the computer off like I always do and came back 2 hrs later and the monitor said no signal detected and my keyboard stopped lighting up but the mouse still lights up. I checked all cables on monitor and tower and they all were tight as possible. I even switched from dp to hdmi and still nothing. Next step I took keyboard and monitor and plugged them into Xbox and they both worked immediately so I knew it wasn’t any of those. Next step I checked all wires inside tower and psu and everything was tight. Checked graphics card and ram all tight. Fans spinning on everything. I took out the little battery on mobo and put it back in to reset the bios/cmos. Again nothing. So I plugged the hdmi into the mobo directly and still nothing. Does that mean the mobo is damaged (hint) why I can’t get a signal and keyboard not working or is there anything else I can try?
Specs
ASUS prime x570 mobo
Ryzen 9 3900x
32gb ram
2080 super graphics card
Be quiet 650 watt psu
Specs
Ryzen 9 3900x
32gb ram
