Monitor No Signal Issues
PinkStahli
9
I just build a co-worker's computer, and I hit a wall. (I'm not a pro)
The build is all set, but when we connect the PC to a monitor (through VGA, DVI and HDMI) the monitor says "no signal' even when we power the rig up. The monitor is hooked up through the video card.
Does anyone know whats up?
Specs: 2500k Core i5
6gb Corsair Memory
GTX 560 Ti 2GB
AsRock Motherboard.
Well on the new PC you didn't tell what model of AsRock board you does it have an onboard GPU if you so you have to connect the monitor to that and go into the bios and change the the display from on board to PCIe. If it doesn't have an onboard then its best to disconnect everything except the CPU/memory/GPU and see if you get anything on screen for memory only have 1 stick installed as well. You don't need CD/HD/Keyboard/mouse to see a post screen.
Also 6gig's seem a bit odd what sticks are you running 2x2x2 ?.
