Question Monitor no signal, motherboard error 97, really need help. Tyvm.
5
Just built my first ever pc and after installing windows 11 pro and downloading and updating drivers etc for not even use for more than 2 hours.
After trying to restart as per prompted but system due to updates, motherboard shows g code 97 continuously even after I tried powering off and on a few times.
Rolled back bios to post versions (0805 n 1212) and back to latest 14 version still getting 97 error code.
Tried clearing CMOS from button, pulled out battery etc (after powering off pulling out power supply cable), reseated gpu in slot 1 and 2 still same (initial boot up used slot 2) slot 3 not accessible as gpu too bulky)
Strix x670e-e gaming wifi
Thor plat ii 1000w
Samsung 980 pro 2tb ssd
No HDD
MSI suprim x 4090
Ryzen 9 7950x
Windows 11 pro
Noctua nh-d15 (CPU cooler)
Corsair 7000x
Benq ex3415r
Everything turns on lights fans etc but monitor just keeps showing no signal and motherboard error 97
Really need advices, tyvm.
Jul 2, 2023
5
Something to suggest that its the GPU that making this code. Try and Restart to the bios and enable legacy mode to see if the 4090 is recognized.
Tried entering bios with gpu slotted but monitor just shows no signal, only if I removed the gpu and connect via dp to motherboard will there be any boot image showing up on monitor.
Jul 2, 2023
5
Hopefuly someone can come help you more and give you more ideas if you cant get into bios because csm is disabled! Your system is not recognizeing the 4090 and hopefuly you can get this fixed
Appreciate your help so far, hopefully there will be more advices, really at a lose of what to do now. :(
