Question Monitor "no signal" problem occurs sometimes.
Mar 10, 2021
My specs -
Mobo - MSI tomahawk x570 elite
CPU - AMD 5800X
GPU - MSI VENTUS RTX 3080
Ram - 16X2 3200mhz
SSD - Auros M.2 1TB
HDD - 1TB
PSU - Cool Master 850 watt gold plus
I built this system a month back. I sometimes get the no signal. Once, it got too much and wouldn't fix itself no matter how many times I restarted.
I checked the RAM and GPU by taking them out and inserting them again. But, it was not the problem. Then I noticed the fan on the motherboard.
Whenever I turn on the PC, the motherboard fan would start running at full speed, but it would adjust itself soon after and the system would run fine. However, sometimes it won't and keeps on running at full speed, and only in those cases would the "No Signal" problem occurs.
Is there some motherboard issue? Maybe it is sending a signal that the system is overheated? Should I update the BIOS? Or could it be a defective Motherboard?
