Monitor no signal via DVI-VGA Adapter
drewcula
Specs
http://www.newegg.com/Product/Prod [...] 6883227339
Phenom II X4 955(3.2GHz)
4GB DDR3 1TB HDD Capacity
NVIDIA GeForce GT 520 (1 GB)(Replaced)
Windows 7 Home Premium 64-bit
PSU : SeaSonic S12 Energy Plus SS-650HT 650W ATX12V V2.3 / EPS1
New GFX : EVGA GeForce GTX 560 1024 MB GDDR5 PCI Express 2.0 2DVI/Mini-HDMI SLI Ready Graphics Card, 01G-P3-1460-KR
Adapter:
Amazon.com: StarTech DVI to VGA Cable Adapter, M/F (DVIVGAMF): Electronics
(StarTech DVI to VGA Cable Adapter, M/F (DVIVGAMF)
Current Monitor is like : http://www.saintclassified.pk/uploads/dell-17-inch-fresh-5e2ed.jpg
I bought a new PSU and New GFX card and an adapter because the GTX 560 has 2 DVI connectors. So I seated the GFX, Put in the pins, try both slots with the adapter and the monitor(VGA), but NOTHING APPEARS.
I tested with old GFX(520) and monitor is fine. I tried reseating GFX card, different 6 pins from the PSU, different VGA monitor and adapter, replugging in the cords for PSU and Monitor, onboard VGA slot but none of these worked.
I can't see or do anything with the VGA Monitor unless it's with the old GFX card. Please help!
clutchc
Herald
Your links are broken, so I can't tell which EVGA card you have. But to use VGA from a DVI connector on the card, the connector has to have the 4 pin holes surrounding the flat blade. Those are the VGA signal. Likewise, the adapter has to have the 4 pins surrounding the flat blade. Does your setup have that?
Similar threads
