[SOLVED] Monitor No Signal - went fine after PC restart
Jun 14, 2020
12
Help. I have a monitor and when i turned on my PC, my monitor suddenly became "no signal". My pc has power, the monitor has power. When i reset pc. The monitor workes.
What's the possible cause of this? Any possible damages inside my pc that i need to check and anticipate?
Thank you!
D
Try the following steps:
0. Try using onboard graphics: is the problem solved? (Yes -> issue is GPU / No -> OS issue/Cable/Monitor)
If YES:
  1. Check for driver updates for your GPU
  2. Check for OS updates for Windows
If NO:
  1. Check your display cable
  2. Check using another oport on GPU (you should have both VGA or HDMI)
  3. Check monitor settings
When has this started? Have you changed any settings? Is this a new build?
If YES:
If NO:
Ok thank you. I will try to do this when it happens again. 2 months ago maybe. I dont know if this is normal because it was totally fine. It's fine now but im worried. 😭
