C camcamcamcam Prominent Oct 30, 2018 6 0 520 Oct 30, 2018 #1 Is there anyway I can fix this? im not in the best position to buy another one.It's been working fine for 22 months
Solution hang-the-9 Nov 1, 2018 camcamcamcam : uppercut4u : Remove the card and reseat it. Try another PCIE slot. Make sure all power cables are firmly attached. Try in another PC I reseated it and I can't try it out in another PC i've been working on this for 10+ hours and I can't return it If you can't test it in another system or contact warranty for it, only thing you can do is try another video card in your system.
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Oct 31, 2018 #2 First step, test the card in another system. If the card is bad, did you contact warranty support? Upvote 0 Downvote
uppercut4u Reputable Mar 22, 2018 346 10 4,915 Oct 31, 2018 #3 Remove the card and reseat it. Try another PCIE slot. Make sure all power cables are firmly attached. Try in another PC Upvote 0 Downvote
C camcamcamcam Prominent Oct 30, 2018 6 0 520 Oct 31, 2018 #4 uppercut4u : Remove the card and reseat it. Try another PCIE slot. Make sure all power cables are firmly attached. Try in another PC I reseated it and I can't try it out in another PC i've been working on this for 10+ hours and I can't return it Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,372 1,081 152,940 Nov 1, 2018 Solution #5 camcamcamcam : uppercut4u : Remove the card and reseat it. Try another PCIE slot. Make sure all power cables are firmly attached. Try in another PC I reseated it and I can't try it out in another PC i've been working on this for 10+ hours and I can't return it If you can't test it in another system or contact warranty for it, only thing you can do is try another video card in your system. Upvote 0 Downvote Solution
