Monitor No signal
KapootaG
Commendable
Jan 9, 2017
4
Hey, I'm a first time builder for a pc and I bought an AMD Ryzen 3 2200g with Vega Graphics. My PC works, but my monitor has no signal and I was wondering if my motherboard doesn't support my integrated Vega graphics.
My model for the motherboard is ASUS Prime A320M-A, I know it supports 'AMD Radeon R Series Graphics 7th Gen', but my QUESTION is if it supports the onboard Vega Graphics, if it doesn't then I'm going to buy a graphics card!
SIMPLE question, plz answer, thanks.
Do you have any way of verifying that you're on the latest BIOS update for the board? Can you please pass on the specs to your proposed build like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
If you've installed the components correctly, the power requirements are met and you haven't broken anything on the board, I'd suggest taking it to the store you purchased the board from and ask the retailer to update the BIOS on it if it's not.
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
If you've installed the components correctly, the power requirements are met and you haven't broken anything on the board, I'd suggest taking it to the store you purchased the board from and ask the retailer to update the BIOS on it if it's not. /
CPU: AMD Ryzen 3 2200g (Vega 8 Onboard)
GPU: None yet, which is why I'm asking if I need one.
MOB: ASUS Prime A320M-A
RAM: 1x8GB RAM DDR4
PSU: Thermaltake Litepower 450W
HDD/SSD: No SSD, Seagate Barracuda 1TB
CHASSIS: Phantek Eclipse P3
