Hi, need some help here please.
monitor acer cb342ckc (a) connect via hdmi to hdmi to pc ASROCK J5005. Same monitor, also connect from laptop usb c to monitor usb c.
both can have display with I select input for hdmi and usb c respectively.
the problem comes in when I toggle out of hdmi to usb c and back to hdmi, the pc will not have signal. But when toggle back to usb c, everything is fine. Have to unplug everything and redo then hdmi get signal back from pc.
I tried removing usb c and just plug hdmi to pc. Works normally, but when I toggle input and let it recycle 1 round back to hdmi, no signal appear. It seems like when connected to pc, I cannot toggle out of the hdmi otherwise signal will be lost.
anyone has any idea what is going on?
- Tried on another monitor (b) or tv, no issue with toggling.
- so I tried to change my pc to another laptop and hook up the laptop via hdmi, so 2 laptop connected to monitor (a) can toggle between hdmi and usb c no issue.
