Skorvan Commendable Jul 1, 2020 13 1 1,515 Jun 21, 2022 #1 I recently got a benQ Zowiee XL2411 from a friend and when I went to change the color settings it doesn't let me change the Gamma, Hue or Saturation. They are just greyed out and can't be selected. Is there a way to change them?
Solution kerberos_20 Jun 21, 2022 you can change those in gpu driver settings, otherwise it will work from monitor once you connect it with d-sub cable (vga)
kerberos_20 Champion Dec 24, 2011 9,921 1,593 55,740 Jun 21, 2022 Solution #2 you can change those in gpu driver settings, otherwise it will work from monitor once you connect it with d-sub cable (vga) Reactions: Skorvan Upvote 1 Downvote Solution
