[SOLVED] Monitor not displaying
Ralston18
Make and model monitor, connection type? Age, condition?
Is the monitor on (showing signs of having power) via LED's, power light, etc.?
Be sure that the monitor is plugged into a working wall outlet. (Check for tripped breaker or blown fuses.)
Have you tried other known working video cables? Other power cables.
It the monitor connected to a GPU? If so. remove the GPU and try the motherboards built in video connection.
