My PC was working fine until one day I decided to reverse the CPU cooler, it was jutting into one of the dimm slots but I only had one stick of ram anyways. I was very new to pc building so I don't know to put thermal paste back on to the CPU when replacing a cooler. Long story short I broke a CPU pin off and got a replacement, but when I put it in the monitor wasn't getting a signal.( I know I'm really stupid please don't tell my more but I went through I guide and after I checked to see if everything was right the last thing it
said to check was the cpu. I was very tired and hungry at that point from troubleshooting for about 5 hours and i Idk why but I tried to put the CPU cooler back on without thermal paste. A couple pins bent but I might try to fix it because it's no use to me rn.) I tried multiple monitors so that wasn't the problem there was a red light near the gpu in the motherboard whenever I tried to boot, no beeping. The PSU is the only part I can say was working for sure because all of the fans were spinning. The hard drive plastic price that it used to connect coulve screwed up the motherboard or something idk. I tried my windows boot stick that I knew was working but the computer wouldn't even boot into bios. After all that is when I broke the CPU which means it's obviously broken now but something else is broken inside the pc also. I'm 15 and lost a job, so I'm trying to find a new one. I am trying to figure out what parts i need to get because I would not like to waste 100-150 dollars on a part I don't need. Any help is appreciated, thanks.
This was my build
ram: https://www.amazon.com/dp/B01ARHBBPS/ref=cm_sw_r_sms_apa_AQSjBb225P2FJ
hard drive: https://www.amazon.com/dp/B01IEKG402/ref=cm_sw_r_sms_apa_uRSjBbWVJHBHV
cpu:
https://www.amazon.com/dp/B0741DLVL7/ref=cm_sw_r_sms_apa_eSSjBbWK68P83
gpu:
https://www.amazon.com/dp/B01M4KGTNI/ref=cm_sw_r_sms_apa_4SSjBbBS35TD6
motherboard:
https://www.amazon.com/dp/B074QD4L59/ref=cm_sw_r_sms_apa_GTSjBb1QMHGB8
power supply:
https://www.amazon.com/dp/B074ZDLGM3/ref=cm_sw_r_sms_apa_hUSjBb4JZH680
This was my build
cpu:
gpu:
motherboard:
power supply:
