Question Monitor not reciving signal [ Solved]
Sep 6, 2024
So yesterday i upgraded my PC (Only two more 2x 8GB ram sticks, they are compatible) but the Monitor(A Philips TV) is not showing input from the PC, could this be due to the HDMI Cable being broken or something else?
Edit: After looking around more online, i found out that XMP was causing the issue, the reason i found it out was the fact that it always worked with only 2 RAM sticks, no matter if the new ones or the old ones so i went into bios and forced them to run at 2400mhz afterwards i put the two extra ramsticks in and it worked.
