Monitor not turning on, power light blinking green
JohnBiceps
11
So my monitor is not turning on, display is showing nothing, power light is blinking green and its making tick noise when it blinks. Its connected to gpu via vga->hdmi adapter(changed 2 of them).Cable is good(changed 2), gpu is also good because with other monitor its working alright. What can be cause of it? my bet is that its stuck in sleep mode or something is broken in video link part.
ALSO: its working when I take gpu out and connect it to motherboard. Also it works if after that I put gpu back int.
so what I need to do? It worked like charm for 1 year
oh sorry, but I wrote that other monitor is working fine so its monitor problem
Use HDMI, DisplayPort, or DVI-I, DVI-D.
MERGED QUESTION
Question from JohnBiceps : "Monitor not turning on, power light blinking green"
Does your monitor have HDMI, DisplayPort, DVI-I, or DVI-D? If not, then it lacks the circuitry and the wire does not exist.
