Monitor not working in dual monitor setup
linxpeter
Commendable
Sep 28, 2016
So, where to start...
Today I tried something that I've never tried before. I tried to connect another monitor to my PC to make a dual monitor setup. The monitor that I was using before works perfectly with an HDMI cable. But the second one which I wanted to connect afterwards just doesn't want to work. If I plug the HDMI into the monitor and into the PC it doesn't recognize that I've connected it. If I try to select HDMI in the source menu it says there is no cable connected.
Things that I've tried:
- Replacing the HDMI cables (WAS = without any success)
- Factory resetting the monitor (WAS)
- Plugging in the monitor into my PS3 to see if that works. (IT WORKED!!!)
- Downloading a driver for the monitor (WAS)
So yeah, it seems to me that the monitor doesn't want me to have a dual monitor setup 🙁
Any ideas?
Thanks,
Peter.
P.S: Sorry if there are some mistakes in my english, I'm hungarian and 14 years old 😀
mobo: Asus A55BM-A
cpu: AMD Athlon X4 750k
vga: Gigabyte GTX 750 Ti
ram: 8gb ddr3
monitor no.1: lg d2343p
monitor no.2: samsung T27D390EW
