Ok I'm back, not wanting to be beaten and in desperate need of a functioning pc and not wanting to pay a sunday call out fee....
I have taken the cpu apart, cleaned it and put it back together. The fan runs fine as do all the other fans, the hard drive and everything else work and it all sounds as it normally would, don't know if that piece of information helps. But there is no beep.
Having done some googling I have read that the beep is from the video card, is this true? I have also read that you can connect the monitor to the motherboard if it has the right connectors but I've looked and can only see an old style printer conector and a 9-pin connector which I don't recognise.
Another thing is this, when I removed the video card from the motherboard and turned it back on the message on the monitor came up as 'check video card' however when the video card is connected the monitor says 'Monitor Status - VGA input: no input signal'
Does any of this narrow it down?
