[SOLVED] Monitor "Out of Range" error with new build
May 20, 2020
7
I just finished building my first PC with the following specs:
PCPartPicker Part List: https://pcpartpicker.com/list/msgLL2
CPU: AMD Ryzen 3 3200G 3.6 GHz Quad-Core Processor ($91.50 @ Amazon)
Motherboard: MSI A320M-A PRO MAX Micro ATX AM4 Motherboard
Memory: Patriot Viper 4 Blackout 8 GB (2 x 4 GB) DDR4-3000 Memory
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive ($67.99 @ Newegg)
Case: Cooler Master N200 MicroATX Mini Tower Case ($49.99 @ Amazon)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($71.98 @ Amazon)
Monitor: Asus VA229HR 21.5" 1920x1080 75 Hz Monitor ($99.00 @ B&H)
Keyboard: Redragon K552-N Wired Standard Keyboard ($33.99 @ Amazon)
Mouse: Logitech M310 Wireless Laser Mouse ($17.99 @ Best Buy)
Total: $432.44
Generated by PCPartPicker 2020-05-20 21:01 EDT-0400
When I press the power button, CPU and case fans start spinning, Ethernet light blinks, and keyboard lights up, but the monitor shows "Out of Range". I have checked that monitor works fine with my laptop when connected using the same HDMI cable.
The MOBO supports a maximum resolution of 1920x1200 @60Hz via DVI-D port and supports a maximum resolution of 4096x2160 @24Hz via HDMI 1.4 port.
The Monitor supports a maximum of 1920x1080 @75Hz via VGA port and a maximum of 1920x1080p @ 60Hz via HDMI 1.4 port.
Please help, I have spent all the money I have no idea what mistake I made.
how it is seen in uefi dor screen size and see if you could set the igpu output to screen panel on monitor .
I am unable to get the BIOS screen. The monitor just displays the "Out of Range" message as long as the PC is running.
I tried smashing various keyboard keys, but no luck.
now you could try to set the hdmi resolution from the os panel .
I tried connecting to HDMI using DVI-D to HDMI and HDMI to HDMI cable, but the monitor gives the same "out of range" error. I think the monitor has better support via VGA. Here is the relevant page from the monitor manual:
However, since the VGA adapter that I am using supports only upto 60Hz, the monitor doesn't give me a 75Hz option.
Can you please elaborate on the steps I can take to make HDMI work?
page 3-5 input settings then 3-9 image centering and use the last 1920x1080 settings at bottom of page and whhat happens if you choose lower screen size on hdmi .
So I tried connecting via HDMI to HDMI cable, and the "out of range" error appears until the operating system is loaded. That is, I can't access BIOS when using HDMI. Do you think there is some problem with motherboard? How can this be fixed?
