Monitor out of range, tv works
Nicolas_21
Commendable
Aug 14, 2016
24
Hello,
I tried connecting an LG monitor to my recently built pc, but wont work. It says monitor out of range, and then 33Hz / 30 Hz.
I plugged it in my TV and it does work. I managed to install windows 10.
Is it possible to make the monitor work? I'm tried of settipng up the pc on the tv screen...
Sounds like your refresh rate isn't set properly on the PC and it's a rate that the monitor isn't able to display. Go to your graphics card's settings and ensure the output is set to 60 Hz, that should fix it.
