Question Monitor power issue
May 10, 2021
38
Hello there! I've a budget oriented SAMSUNG LF22T350FHW monitor. I've a weird and a very slight issue with the monitor. If I keep the monitor plugged in into the socket turned on for a few hours, I've to press the power button twice on the monitor for it to work properly after I've turned on my pc, otherwise the display stays turned off. But if it's just for only an hour or so, it works fine. I'm wondering what is happening?
Off Timer: Turn on Off Timer mode.
•• Turn Off After: The off timer can be set within a range of 1 to 23 hours. The product will automatically power off after the specified number of
hours.
‒‒ This option is only available when Off Timer is set to On.
May 10, 2021
38
hours.
Dude this problem occurs when my pc is turned off but the monitor is still connected to the power source receiving power. Does turning off the off timer still applies here?
