Monitor Problem *Help!* :(
Evoked
5
So the left half of my monitor just got a red tint for some reason, its also kind of grainy (only on the left side), i think its the monitor because its only the left half of the screen and my other screen is fine. Its also not like straight half its like a gradient becoming stronger red tinge and grainier the closer it gets to the edge
Is this something fixable or will i have to replace it?
if you need my specs:
3570k
8gb ram
AMD 7950
you can try using the temp and color bars in your menu and slide all the way to one side to see if that will shock it backinto place but even if that works it is only a quick fix and is a sign your monitor is going bad, if it is still under warranty send it back and get a new one
