Monitor problem [HELP]
Jul 20, 2017
I dont know why my monitor has this problem:
7QDXn
http://imgur.com/a/7QDXn
It looks like there are small lines between each pixel. Is there any fix ?
I have arleady tried changing HDMI cable/port.
Monitor: LG M2352
Thank you !
i think that red ish color issue is caused by the settings, and i think the pixel more visible only because the color and it is a common thing if the pixel really visible especially if you are using a tv that doesnt really have sharp image quality. try using display color calibration settings in windows or maybe try to reset the tv settings
