Question Monitor problem
Oct 12, 2019
i recently got a new monitor
The problem is that the characters get dizzy and green around them, example when i play fifa the characters get a green shadow around them and gets unclear. It just happens through the HDMI. Tried to change HDMI cables didn't work
Oct 12, 2019
Does the monitor have any kind of self calibrating feature ?
Do you have access to other cable standards between monitor and GPU, like DP or DVI ?
No, don't think so. This is not between PC and Monitor. That works fine, it's between the playstation and monitor (ps can only take hdmi). The playstation works great on the other monitor with 60hz. But on the new monitor with 165hz the characters gets blured and has a green shadow around them when running.
kaehligj
335
26
695
4
You have a settings problem on either the monitor or the PS.
Set your new monitor to 60Hz and take it from there.
I'm certainly no expert in this, but the best way to go is to set both devices on the same fps.
If the PS can not go more than 60HZ, then that is what your monitor must be set to.
You will not go better than lowest on the 2 - no matter what you try.
