My monitor is 4k LCD UHD. It is nearly four years old now. When turning it on the maker name/logo (Japannext) appears and then it is up and going. But recently, instead of showing the name, it flashes white like it is putting up the name all blurred kind of. Then it emits what sounds like a quiet but very high pitched sound and the screen kind of goes grey/black. At that point the screen seems to be locked and nonfunctional as the remote buttons make a red light kind of flash at the bottom of the monitor like it is getting the message but it then will not display its usual message on screen. Also, at that point, when I turn on my computer (which I always do after seeing the name/logo) the computer turns on fine, but the screen just remains grey/black, not showing the start up screen from the computer etc. If I play with it--that is, turning the monitor on and off half a dozen times, eventually the name/logo appears and then all is well, and there are no more problems. But my question is, what is doing this? Could a room temperature of say 12-15 degrees C do that? Is there some kind of problem with the monitor hardware? It is obviously not the computer, as it is not even on when this happens. Also no cables are loose--like the power cable. Any help would be great. Thanks in advance.
