Monitor Problems...
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi, I'm new to this forum as I usually try and solve problems one my own
but this one has me stumped...
I have recently managed to upload VHS to my PC at home and installed
programs to do so. I wanted to begin editing when the editing program
'Ulead Video Editing V.8' refused to start, claiming my screen
resolution was 'too low to play videos'. I then increased the
resolution on my 14" monitor, but to no avail, the same message
appeared. I therefore decided to get out a 17" monitor I had laying
around (wasn't used before due to space issues) and try that.
I plugged it in, but now there is NO DISPLAY until a green Windows XP
screen appears, only appearing in the middle of the screen with a
default blue boarder, and the system ceases to load.
In my wisdom I then decided to try and put the other monitor back on,
believing that there may have been a compatibility problem, but I now
have the same problem again.
Anyone have any suggestions?
Thanks
Mark
new_horizon
Malke
3,000
> own but this one has me stumped...
Since you attached the computer to a different monitor and still had
display problems, the issue is not with your monitor but probably with
your video card. Swap it out for a known-working one. If you don't have
an extra video card lying around, take the machine to a professional
computer repair shop (not your local equivalent of BigStoreUSA) and
have them test it for you.
Good luck,
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
Similar threads
