[SOLVED] Monitor problems
Avares
170
Hello.I have a strange problem with my LG 27GP850P-B 27" monitor. This is a 1440p monitor that was running great until now.
LG 27GP850P-B
When i play Alan Wake 2 for the first time i accidentally turned on the HDR form the game...and i can't turn it off now. Before that my monitor settings was HDR OFF and adaptive sync on "extended". Now if i turn on the extended version of adaptive sync it turns on the HDR .If i play on adaptive sync "basic" the hdr is off as it should be.
This is very weird because before i play Alan Wake 2 my monitor settings are hdr off and adaptive sync on extended.i try to reset the monitor setting but still is bad.
iF somebody know how to fix that i will be very happy because i realy need adaptive sync on "EXTENDED".
Please help.
Wait so this display has both Free-Sync and G-Sync............................but your saying Adaptive Sync like you know which one your using................but why does it matter if HDR is on in game you could just turn it off or turn it off in Windows..............I don't really see the problem with this cuz it seems pretty simple to me...........................
I don't think you understand exactly what i am writing.I have adaptive sync(that is the name of that sync).That "sync" have 3 tipes of mode-OFF,basic and extendet.Before i use 165 hz mode,extendet version of the sync,HDR off.respons time on fast and motion blure reduction on 0( mean turn off).NOW someting happened and if i use extendet mode it AUTOMATIC turn on the hdr and i can't turn the HDR off because from the menu i can't scroll down to that mode so i can't turn it off.Before i play Alan wake 2 i use to be able to do that.My monitor have adaptive sync and because i am whit nvidia card i guest i use g sync compatible mode by default.
Do you understend now.Is like someting goes bad...or got some kinda bug or whatever but now i can't play on extendet sync whith hdr off...only whith hdr on.
If somebody know how to fix that please wright to me.
And btw how to turn off the hdr from windows.
I just whanna say that i FIXED IT.
I turn the HDR off from the windows setting and now i can use extendet sync whit HDR off.
i seems that some kinda bug apear because i can't turn off the hdr from the monitor menu but in the end i got what i need...so the problem is fixed.
Thank you that you tell me about the option to turn off the hdr in Windows.
