My monitor quickly turns pink after I log into my computer(Right after the windows 10 login screen). It doesn't go pink when I'm in UEFI or when I haven't gone past the windows 10 login screen. I'm using a VGA cable with a DVI adapter connected to a nvidia GTX 960. When I use a different VGA cable I still have the same problem and I've tested it with another monitor. So is it likely a problem with the Graphics card or the VGA to DVI adapter?
Note: I don't have trouble distinguishing between red, green, and blue its just like the entire screen is coated in a see through pink cover.
Edit: The color dis figuration might be better described as everything being a little darker while everything white has a pinkish hue/tint to it
