It's not the monitor. Tested this. There are no weird temp increases or decreases in either GPU or CPU.
Used driver cleaning software to clean out every trace of remaining drivers and installed fresh ones.
Haven't tried a new PSU or GPU. It did make an intermittent whirring sound then went silent and then repeated. This stopped when I switched to on-board graphics and stopped using my dedicated GPU.
It's been running fine using my on board GPU. No signal loss or glitchy screen since.
Before I go out and buy a new GPU, do you guys reckon this is the problem too? My old GPU is still plugged into the motherboard and fans are still spinning so I guess it's still drawing power. Whining noise and signal/freezing issues have been solved just by using on board graphics.
