1. What Is Your Country Of Origin?
Brasil
2. What do you plan to do with this monitor?
Gaming, general use, software development, overall watching stuff (Movies, Series...)
3. What resolution and screen size do you want?
27" would be ideal. Nothing bigger than 32~34"
4. What refresh rate do you want? (ex. 60 hz , 70 hz.)
120hz min, 144hz ideal.
5. How much are you looking to spend?
Things are overpriced in Brazil, $800 is the absolute madlad max.
Something less than $650 would be ideal.
6. Brands Preferred (ex. Samsung, Acer, Asus, AOC, HP, Viewsonic, etc. )
Something more common would be better, brands like Viewsonic are imported to Brazil, thus making it 2x more expensive (Apple style)
7. Brands Not Preferred (state reason why)
HP, maybe. I don't trust them with anything outside of printers and even that...
8. Are You Buying More Than One Monitor?
No
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable?
GeForce GTX 1060 6gb. 3 DP 1 HDMI
10. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc).
Display Port
11. Is This Monitor A Primary Display Or A Secondary Display?
Primary. I don't enjoy multiple monitors setups that much to be honest.
12. Is This A Secondary Display For A Laptop?
No.
Additionally, no curved monitors and nothing really additional on it like (RBG stuff, DAC and fancy design)
Brasil
No
Display Port
No.
