powersourcefortnite :
Calvin7 :
Product Preset Modes
In DVI/DP connection mode
1920x1080
(60/120/144Hz)
When the resolutions are
2560*1440@60Hz/
3440*1440@60Hz/
1920*1080@144Hz/
2560*1440@144Hz/
3840*2160@30Hz connection via DVI port, pls choose 24+1 pin double - channel DVI cables. AKA DVI-D Dual Link cable
POWER/MENU Key: Press this key shortly to pop up Main
Menu/Confirm; hold this key to power off.
To change resolution refer to graphics provider. It depends on what you are using as a graphics solution. A PC graphics card comes with software to change resolutions.
Can't I use MSI Gaming OSD software for settings?
This is how you change your monitor's refresh rate in Windows 10:
If you're using
DisplayPort or DVI,
right click your desktop and click
'Display settings'.
Scroll all the way to the bottom and find the
'Advanced display settings' option.
http://
In there, you should see your monitor and what it's currently outputting. If it shows
144Hz, you're good to go, if not, click
'Display adapter properties' underneath the section of the
MSI Optix MAG24C.
http://
A
small window should pop up that has
3 tabs at the top, each named
Adapter, Monitor and Color Management. Click
'Monitor'.
In here, there should be a
drop-down menu under the subtitle: '
Refresh Rate'.
http://
Click the drop-down and select
144Hz.
(Note that
144Hz will
only be available if using a physical
DVI dual-link or DisplayPort connection and if you are at a resolution of
2560x1440/1440p or 1920x1080/1080p or lower, though a few lower resolutions do
not support
144Hz.).
The links are images to show you what each step should bring you to.
Hope this helped.
