Monitor says no signal
sanderveski
20
monitor says no signal. pc turns on all fans and lights turn on as they should, keyboard doesnt light up and fans are at 100% speed all the time. dead psu?
it worked just fine the day before
specs:
ryzen 7 1700
zotac 1070 amp extreme
asus prime b350 plus
corsair vengeance lpx 16gb 2666mhz
corsair builder cx500 500w psu
check your ram chips, make sure they are all seated correctly. if they are try removing all but one chip.
i recently had the same thing and it was a ram chip not seated correctly
had the same thing years ago and it was a ram chip that went bad.
