Monitor says out of range
Jonnes
11
So 2 days ago my 2 monitors (BenQ XL2411 and an Asus wh192d) were working just fine, but a night after that my secondary monitor which is the Asus started saying "Out of range" and i cant when i try to change the resolution it wont fix it even if done in safe mode. It works fine if i use only the Asus monitor but when i connect my benq also it just starts saying out of range again, I have an amd fx 6300, r9 380x 4gb and 8gb of ddr3 1600mhz ram.
Did you make any V-Sync changes to either monitor recently? Only thing that comes to mind is the difference in refresh rate of those two monitors. Resolution shouldn't matter.
That message usually refers to a monitor receiving a signal that is either out of the refresh rate range or out of the resolution range or both.
I havent done anything to my remembering, but all of my different game resolutions had changed too,
for example CS:GO had changed from 4:3 streched to normal 4:3 (black bars on the side)
