Question Monitor shows no display. HELP.
Apr 13, 2020
6
Last night I noticed my computer seemed a bit slow, I decided to head over to https://www.userbenchmark.com/Software to test my PC parts. I noticed my ram was underperforming so I opened my PC up to change the slots the ram were in. In order from left to right, the ram was in slot 1,2 I moved it to 2,4. Ever since I have not been able to get a display on my monitor. I have tried everything from reseating the ram to resetting the CMOS battery to no avail. I would appreciate any insight into this problem. I'm not sure what to do. I have also noticed that other people with my same ram have had the issue. Keep in mind I did not have this issue until I reseated the ram.
The ram: https://www.amazon.com/G-Skill-Ripjaws-288-Pin-Desktop-F4-2400C15D-16GVR/dp/B013J7T5K6
same issue same ram: https://forums.tomshardware.com/threads/monitor-not-receiving-signal-when-installing-new-ram.1563308/
previous post of mine: https://www.reddit.com/r/buildapc/comments/g0o86p View: https://www.reddit.com/r/buildapc/comments/g0o86p/monitor_shows_no_display_help/
I would appreciate any help with this, I'm unsure if I should buy a new motherboard, new ram, or there is a fix to this problem I haven't found yet.
Apr 13, 2020
6
Yea it's a confusing situation for me, I already purchased new ram and motherboard. Gonna try new ram on the same motherboard first. My current motherboard has no troubleshooting features, so there is no way for me to tell if it is the motherboard or ram itself messed up. I talked to another person about it and they believe its the ram slots fried. You think it's the actual ram sticks?
