[SOLVED] Monitor stand options?
Griever0by0birth
6
Hey all, I am looking for a way, preferably not a wall mount, to have a smaller panel above my 32'' tv. I am aiming for around a 24-26'' panel that I can have as a secondary while I am gaming on my min screen. Any suggestions?
Ergotron makes all kinds of high quality monitor mounts.
https://www.ergotron.com/en-us/products/mounts/multi-monitor
I happen to like wall mounts. They clean up space on your desk.
Also, I think a second monitor is better placed to the side if you have the room.
I have a 40" main monitor and a 30" side monitor oriented vertically using a wall mount like this:
Be advised, they are pricey but the quality is tops.
Well, I do have a large standing desk, but my issue is I am in a rental house, and do not want to put things on the walls. Which is why I am looking for something that can A: Bolt or B: Clamp into the desk, preferably the latter of the two, just in case I decide to part with the desk itself. Thanks for the link though! I will check them out.
