Try another adapter.I bought a Nvidia quadro 4000M 8gb and It only had display ports so I had to buy a vga adapter adn now my resolution won't go higher than 1280 x 1024. I updated my drivers already adn my monitor is a 28 inch 60 hz 1980 x 1080 DELL monitor, that's all I know.
A Lanberg one, that's all.Some of those adapters will limit the resolution. (it will also mess with windows because windows will not 'know' what the model of monitor is and might not allow you to choose different resolution(s). Can you post which DisplayPort to VGA adapter you have?
Look at the guide below, read the section;
How to set custom resolution on Windows 10?
How to create custom resolutions on Windows 10 [EXPERT GUIDE] (windowsreport.com)
