Question Monitor suddenly displays "No signal detected“ ?
Nov 4, 2024
Hello guys,
I have a problem with my PC (built in 2017, specs as attached).
The day before yesterday the monitor suddenly displayed „No signal detected“, and I can’t get it to work again.
I have already tried the following:
- Checked the cables and the monitor, that’s not it. Both work fine.
- Put the graphics card in the second PCI-E slot.
- Replaced the graphics card. Didn’t work with the other one either, and the other one works fine in the computer from which I took it out.
- Cleaned the RAM sticks, tested with only one stick inside, in different slots.
- Took out the CMOS battery and drained any leftover power by holding the power button.
- Took off the CPU cooler and added fresh thermal paste.
What else could it be? I would really very much appreciate every assistance here.
Thank you so much.
Hello guys,
Thank you so much.
With such old system at this time could be anything, probably MB but also PSU.
A faulty, or wrongly-placed cable is the most common reasons for a monitor saying no signal. Unplug each cable and then replug them. Ensure each one is properly connected or damaged display drivers
