Monitor Suggestion for a Custom Build
courtney1121
18
1. What Is Your Country Of Origin? US
2. What do you plan to do with this monitor? (ex. Games, Movie Watching, Photo Editing, etc.) playing The Sims 4 and internet use
3. What resolution and screen size do you want? between 18-22" - not sure about resolution
4. What refresh rate do you want? (ex. 60 hz , 70 hz.) Something to run my game smoothly
5. How much are you looking to spend? $100-$200
6. Brands Preferred (ex. Samsung, Acer, Asus, AOC, HP, Viewsonic, etc. ) - Not too picky but something with a good brand reputation
7. Brands Not Preferred (state reason why) N/A
8. Are You Buying More Than One Monitor? no
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable? I think 3 displays - Sapphire R9 270 2gb Dual-X Boost OC
10. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc). - doesn't matter
11. Is This Monitor A Primary Display Or A Secondary Display? primary
12. Is This A Secondary Display For A Laptop? Will be at times if I need to work from home
