M MrLatwian Reputable Feb 12, 2016 49 0 4,540 Apr 3, 2016 #1 So my monitor died. I got a new one a dell e2216h and it has a vga conector Will a gtx 750ti work with it if it dilosent have the vga port it has hdmi.
Solution S S Suzuki@1473780084@1473780163 Apr 3, 2016 Yes, but you'll need a HDMI to VGA converter, not adapter.
S Suzuki@1473780084@1473780163 Dignified Mar 8, 2015 5,280 1 15,960 Apr 3, 2016 Solution #2 Yes, but you'll need a HDMI to VGA converter, not adapter. Upvote 0 Downvote Solution
Wolfshadw Titan Moderator Aug 3, 2006 28,520 1,697 133,290 Apr 3, 2016 #3 If your GTX 750Ti has a DisplayPort output, you could use that instead. The monitor has both VGA and DisplayPort inputs. -Wolf sends Upvote 1 Downvote
