Specs:
450 W PSU
Diamond ATI Radeon HD 4870
After the above happens, I usually have to hard shut down the computer. Sometimes when I start it up again too quickly the screen BSODs and I see artifacts/screen disturbance. If I leave it alone for a while and come back, it works perfectly fine.
I've had this computer for a really long time and had overheating problems with the GPU, but fixed that with new thermal paste. I've only recently ran into this current problem of system crashing, and screen turning off, and it happens randomly whether or not in a game.
I've kept track of GPU-Z logs in the background. Here are the readings (I'll only show the last couple before a crash).
This one is when I was gaming:
Date, GPU Core Clock [MHz] , GPU Memory Clock [MHz] , GPU Temperature [°C] , Fan Speed (%) [%] , Fan Speed (RPM) [RPM] , GPU Load [%] , GPU Temp.(DISPIO) [°C] , GPU Temp.(MEMIO) [°C] , GPU Temp.(SHADERCORE) [°C] , Memory Usage (Dedicated) [MB] , Memory Usage (Dynamic) [MB] , VDDC [V] , VDDC Current [A] , VDDC Phase #1 Temperature [°C] , VDDC Phase #2 Temperature [°C] , VDDC Phase #3 Temperature [°C] ,
2013-01-05 12:53:36 ,750.0 ,1000.0 ,58.0 ,40 ,2706 ,69 ,58.0 ,70.5 ,62.5 ,325 ,74 , 1.2625 ,44.7 ,75 ,78 ,75 ,
2013-01-05 12:53:37 ,200.0 ,3196.9 ,-1.0 ,100 ,0 ,100 ,32767.5 ,32767.5 ,32767.5 ,325 ,74 ,- ,0.0 ,0 ,0 ,0 ,
The same thing happens when I'm watching a video, except with less GPU temps (50ish average for all), and the same crash result of -1.0 and the weird 32767.5 numbers...So I don't think it's an overheating issue, as these temperatures seem fine.
Any ideas guys?
450 W PSU
Any ideas guys?
