Monitor upgrade help plz
Skates212
14
Looking to upgrade monitor currently using
Samsung 21.5 lcd 5ms 50,000 model 2233sw
Looking at a Acer 23 led 5ms 100,000,000 ratio, the monitor is on sale on newegg 80 dollers off
Will this monitor have a better picture then my current one? Led better then lcd?
the acer monitor is http://www.newegg.com/Product/Product.aspx?Item=N82E16824009315 S230HLAbii
my current monitor http://www.newegg.com/Product/Product.aspx?Item=N82E16824001308
I am hoping the acer is better as I ordered it apon waking up this morning then at work started to panic thinking maybe I should have done more research and it may be bad or something. but it sounds good?
I did notice one difference that looks like is in the samsungs favor and thats
acer : 250 cd/m2
samsung: 300 cd/m2
but i don't know what that means
also not sure what the difference is in these two
acer: ACM 100,000,000:1 (1000:1)
samsung: DC 15000:1(1000:1)
LCD Terms
Bezel - This is the metal or plastic frame surrounding the display screen. On LCD displays, the bezel is typically very narrow.
Contrast ratio - The difference in light intensity between white and black on an LCD display is called contrast ratio. The higher the contrast ratio, the easier it is to see details.
Ghosting - An effect of slower response times that cause blurring of images on an LCD monitor, it's also known as latency. The effect is caused by voltage temporarily leaking from energized elements to neighboring, non-energized elements on the display.
Luminance - Also known as brightness, it is the level of light emitted by an LCD display. Luminance is measured in nits or candelas per square meter (cd/m2). One nit is equal to one cd/m2.
Native resolution - This actual measurement of an LCD display, in pixels, is given in horizontal by vertical order.
Response time - The speed at which the monitor's pixels can change colors is called response time. It is measured in milliseconds (ms).
Stuck pixels - A pixel that is stuck either 'on' or 'off', meaning that it is always illuminated, unlit, or stuck on one color regardless of the image the LCD monitor displays can also be called a dead pixel.
VESA mount - With this, you can mount a monitor on a desk or wall. It meets recommendations of the Video Electronics Standards Association (VESA).
Viewing angle - It's the degree of angle at which you can view the screen from the sides (horizontal angle) and top/bottom (vertical angle) and continue to see clearly defined images and accurate colors.
is there going to be a huge difference with 50 luminance less?
also my current monitor supports hdcp but the new one does not, does this meen the new monitor cant actually support hd?
but on the spec sheet it says hdcp support: No
but the monitor says full hd 1920x1080 and everyone talks about using it on ps3 for blu rays etc
so does full hd = hdcp built in?
and sorry for all the dumb questions, I just really wanna make sure I did not waste my money ;P
right, My current montior supports it, and I use it to watch blu-rays using my radeon card. I am wanting to find out does this new monitor work for it also? since the monitor says full hd support, but in the specs it says no hdcp support... but in the reviews people talk about using it to watch blu-rays, its rather confusing
The Acer will not support this playback.
ok thats what I thought, thats why I am getting confused by NewEggs customer reviews of the Acer monitor, atleast 4 of the 13 reviews talk about enjoying blu-rays on the monitor. so those people are lying then
so overall is the acer monitor worse then my current samsung?
I have 60 days to return the acer apon its delivery for a full refund
it was thank you.
I am wondering if the no hdcp support was a typo on neweggs part. since the reviews talk about using it for blu-rays, and hte monitor says full hd 1080p. no way to figure that out though
