I recently bought a new monitor and tried to connect it to my pc in a dual mode together with the old one.
It did not work so i decided to use the new monitor alone but if i connect it with HDMI it works fine, when i connect it on Display port for some reason it decides that an intel hd graphic card is designated to the monitor, my geforce 1080 is working only on the HDMI.
While connected with display port i can't enter the nvidia menu panel and if i connect both i can enter it but i couldn't manage to fix the problem.
In the device manager when the monitor is connected by both port i can see the two monitor cards and clearly one is with dedicated and the other with integrated.
Is there a way to fix it? Can you give me any suggestion? Thanks in advice.
