Monitor Wall mount or stand
wanderingidoit
18
So I need your guy's opinions and expertise. Wall mount
http://www.amazon.com/Cheetah-Articulating-Bracket-Monitor-Displays/dp/B000WOF5L8/ref=pd_sim_sbs_e_5
stand
http://www.amazon.com/Mount-It-Articulating-Computer-Monitors-MI-751/dp/B0052ATODM/ref=sr_1_12?ie=UTF8&qid=1375466551&sr=8-12&keywords=monitor+mounts
but I will be purchasing three of these so that I can use eyefinity with triple monitor set up. I guess my question is whats the pros and cons for using wall mount vs desk stand/mount
Well it comes down to usability. If you will always be using it on a desk then the Desk Mount is the way to go, you'll never have to worry about where you're putting the desk, your monitors will always be there. If you're looking for the 'clean' look and have a nice desk and can hide the cables in the wall it will look pretty nice, but you'll also be dependent on where you can mount the monitor due to finding a proper place to install it on the wall. Overall I'd stick with the desk mount if you're using it on a desk at all times, less to worry about and easier to move the desk around.
