T Tom e Honorable Nov 1, 2013 24 0 10,510 Dec 21, 2014 #1 Hi guys and girls, I am getting a Mac mini which doesn't have a DVD cd drove in it, I was wondering if i could use my monitor cd dvd drive to work on the mac.
Solution digitaldoc Dec 21, 2014 Not sure what your monitor is. Any USB external drive should work to provide the DVD function. http://www.amazon.com/Samsung-SE-208DB-TSBS-External-Drive/dp/B009QBIZ60/ref=sr_1_7?ie=UTF8&qid=1419214886&sr=8-7&keywords=usb+dvd+drive On the other hand, if your "monitor" is actually an HDTV with an integrated DVD drive, than it will not connect to your computer.
digitaldoc Expert Ambassador Oct 31, 2003 5,213 0 36,960 Dec 21, 2014 Solution #2 Not sure what your monitor is. Any USB external drive should work to provide the DVD function. http://www.amazon.com/Samsung-SE-208DB-TSBS-External-Drive/dp/B009QBIZ60/ref=sr_1_7?ie=UTF8&qid=1419214886&sr=8-7&keywords=usb+dvd+drive On the other hand, if your "monitor" is actually an HDTV with an integrated DVD drive, than it will not connect to your computer. Upvote 0 Downvote Solution
