Hello, I have a question about monitors and dp version.
I have an MSI GeForce RTX 2070 SUPER 8 GB VENTUS OC Video Card. It has 3 DP1.4 ports with max resolution of 7680x4320 (3 2k monitors, 2560x1440).
I'm looking at buying the U2717D (older model, less expensive) or the U2719D (newer model, more expensive) dell monitors. These monitors have basically the exact same specs. Except the U2719D (newer model, more expensive) has DP1.4, while the U2717D (older model, less expensive) has DP1.2.
Technically, the gpu can support both models. But, would there be any advantage to buying the U2719D (DP1.4, more expensive) vs the U2717D (DP1.2, less expensive)? Would the U2719D (DP1.4, more expensive) have better picture because it is running on DP1.4 rather than DP1.2?
I hope this makes sense!
