Monitor with good color accuracy for under $400?
grantling
13
I'm looking for a monitor to do some video editing and gaming and the most I want to spend is around $400. I have a color accurate display to watch my final edits on, so I don't need something perfect, just good for the price range.
I'm looking for something between 22-24" and I'd like to have something that won't have any ghosting for when I play games (the new PC I built has an i7 3770k and a GTX 670 so I imagine I'll do plenty of that). Thanks in advance!
You're at kind of an awkward price point where it is tough to decide whether you want a low-end IPS panel or a high end TN panel. (IPS offers superior color and view angle, TN offers faster response times and less motion blur).
Since you asked specifially for nice colors take a look at the LG listed below. It has a 5ms response time which isn't bad (you won't notice ghosting unless you're really looking for it), and a nice complement of IO ports and features.
http://www.amazon.com/LG-IPS236V-1080p-Widescreen-Monitor/dp/B004SUDU9Q
Both of those are solid.
I own the Asus VS248H-P, and am very happy with it for what I paid. There is no issue at all with motion blur even when I look for it, and while the colors don't compare to an IPS panel they are still very good after some calibration. It's definitely a solid option aswell.
Thanks! I did get a VS248H-P but had to return it as one side of the LED was incredibly dim. I'm debating on getting another 248H-P or maybe this:
http://www.amazon.com/Viewsonic-VX2453MH-LED-24-Inch-Ultra-thin-Widescreen/dp/B004LXK8LI/ref=sr_1_2?s=electronics&ie=UTF8&qid=1339960732&sr=1-2&keywords=viewsonic+monitor
At work I use that and a BX2231 and I'm pleased with both. I wish the Asus worked out, I was so bummed out when it showed up DOA. Thank god I got it from Amazon and they're so flexible with returns.
