Monitor with no signal with dvi
Konnanokk
5
Pc works perfectly with HDMI, but I want to use dvi so when I change out the cables pc shows post and ASRock logo on screen but after that no signal, pc still on and fine.
Ah ok. In that case go into display settings in windows and detect displays, that should remove any reference to the second display you had connected. Then swap your cable and you should be good to go.
