Monitor won't always turn on
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
Hi,
The problem I have is with 2 different pc's. One is a Gateway G-6 350
the other is ? But they both do the same thing. Sometimes the monitor will
show the graphics and other times it won't. The monitors I have tried all
work fine with my new pc. So my question is what is causing it to work only
sometimes on the other PC's ?
Thanks for any help with this annoying problem
Ray
"WackoRay" <ray_wacko_foti@NOSPAMhotmail.com> wrote in message
news:rHpyd.9692$Ff3.2381@trndny04...
> Hi,
only
> Ray
Potential causes of these problems are, but not limited to:
1. Failing system power supply.
2. Failing system motherboard
3. Failing or failed motherboard battery, usually 3v Lithium C2032
4. Graphics driver not set to operate at frequency or resolution required by
monitor.
5. Failing graphics card
6. Other unspecified Windows software issues
7. Unreliable monitor cable
A G6-350 is definitely an aging computer that has a graphics card with more
limited capabilities than modern-day graphics cards.
Your best option is to replace the suspect components one at a time... Ben Myers
On Fri, 24 Dec 2004 03:52:39 GMT, "WackoRay" <ray_wacko_foti@NOSPAMhotmail.com>
>> Hi,
>only
>> Ray
Thank You Ben
On the Gateway I suspected the power supply on the other I don't know. it's
got a pcchips mb M747 with on board graphics that I can't get a driver for
it seems.
Thanks again
Ray
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:41cc3a7f.849595@nntp.charter.net...
by
> monitor.
more
Myers
> >> Hi,
350
will
all
> >only
> >> Ray
Ray,
The PCChips M747 board and the typical chassis in which it is installed are
low-quality products, to put it kindly. You might try the PCChips web site for
drivers. If you can determine the manufacturer of the motherboard chipset, that
mfr's web site is also a good place to look. Better yet, replace the
motherboard with one of higher quality, Intel, Asus, and SuperMicro come to
mind, but the latter costs a small fortune... Ben Myers
On Fri, 24 Dec 2004 18:46:27 GMT, "WackoRay" <ray_wacko_foti@NOSPAMhotmail.com>
wrote:
>Thank You Ben
>it seems.
>Thanks again
>Ray
>by
>> monitor.
>more
>Myers
>> >> Hi,
>350
>will
>all
>> >only
>> >> Ray
Thanks Again Ben, The Pc chips is one someone gave to a fellow co worker & I
am trying to fix for him. When I dismanteled it I could see what you meant.
the case is the lightest gauge metal they could have used and the power
supply looks like someone made it in their cellar.
Ray
news:41cc8b26.21500357@nntp.charter.net...
> Ray,
are
site for
chipset, that
to
> wrote:
> >Thank You Ben
it's
for
> >it seems.
> >Thanks again
> >Ray
required
> >by
> >> monitor.
> >more
Ben
> >Myers
> >> >> Hi,
G-6
> >350
monitor
> >will
tried
> >all
work
> >> >only
> >> >> Ray
Could be the cheap power supply or could be the equally cheap motherboard. No
way to tell except to replace them with fully working units, and it may not be
worth doing so. A Power On Self Test (POST) card would give some indication of
the cause of failure before attemping to replace anything.
The PC Chips computer falls into the Greek Gift category, sort of like the
original Trojan horse. I've replaced a lot of failed PC Chips boards for
clients, using Intel or Asus boards, after which the computers kept and still
keep on ticking for a long time.
When the second-(third-?)tier distributor Tech Data went belly up two or three
years ago, I went to the liquidation auction for their local operation in
Northboro, MA. I got excited when I won a pallet of maybe 40 or so bare bones
microATX computer cases with motherboards, floppies and CD-ROM drives. Then I
found out they were PC Chips boards and began testing them. Lots of dead
boards, which is why they were neatly palletized and shrink wrapped. Tech Data
must have taken a beating on them. Serves them right for selling cheap junk. I
got my money back plus a little more by selling working bare bones setups to a
local dealer who knew exactly what he was getting and didn't really care. He is
now out of business... Ben Myers
On Sat, 25 Dec 2004 21:19:02 GMT, "WackoRay" <ray_wacko_foti@NOSPAMhotmail.com>
>Ray
>> Ray,
>are
>site for
>chipset, that
>to
>> wrote:
>> >Thank You Ben
>it's
>for
>> >it seems.
>> >Thanks again
>> >Ray
>required
>> >by
>> >> monitor.
>> >more
>Ben
>> >Myers
>> >> >> Hi,
>G-6
>> >350
>monitor
>> >will
>tried
>> >all
>work
>> >> >only
>> >> >> Ray
If you and your co-worker are not too far away from Harvard, MA (30 mi NW of
Boston, 20 mi NE of Worcester), it would make sense to sell you a replacement
for the PC Chips garbage, stripping the system of what little is useful on it to
add to my spare parts collection. Shipping costs would probably make this
option unrealistic. Lotsa inexpensive decent systems are around... Ben
>Ray
>> Ray,
>are
>site for
>chipset, that
>to
>> wrote:
>> >Thank You Ben
>it's
>for
>> >it seems.
>> >Thanks again
>> >Ray
>required
>> >by
>> >> monitor.
>> >more
>Ben
>> >Myers
>> >> >> Hi,
>G-6
>> >350
>monitor
>> >will
>tried
>> >all
>work
>> >> >only
>> >> >> Ray
Back in the AT supply days, I built a power supply test box out of a
junked Mot 2 way radio test set (not a service monitor, this was a
glorified breakout box with a meter and a speaker) with loads and jacks
for each line that needed loading. It proved to be the only way to
test AT supplies thoroughly. I've never looked at the ATX standard to
see what it would take to build one for ATX supplies,
A motherboard is really not a test fixture.
Yes, but an otherwise disposable (old, obsolete, etc.) mobo plus a POST card is
not too shabby for testing power supplies.
Go for the ATX-12V standard to incorporate P4 & higher end AMD boards.
.... Ben Myers
Ben, I don't think there is anything worth salvaging on it. it's a very
basic system without any cards other than the modem card.I gave him one of
my g-6 gateway's (I had 2) and I'm just trying to get the video drivers to
install in his. I did change the battery on his pc chips mb and it seems to
be working for now.
Ray
news:41cddeef.20245260@nntp.charter.net...
of
replacement
it to
& I
meant.
> >Ray
> >> Ray,
> >are
> >site for
> >chipset, that
come
> >to
> >> wrote:
> >> >Thank You Ben
> >it's
> >for
> >> >it seems.
> >> >Thanks again
> >> >Ray
> >required
> >> >by
> >> >> monitor.
with
> >> >more
time...
> >Ben
> >> >Myers
> >> >> >> Hi,
> >G-6
> >> >350
> >monitor
> >> >will
> >tried
> >> >all
> >work
> >> >> >only
> >> >> >> Ray
Ray,
Right. The PCChips so-called dual (Socket 370 and Slot 1) motherboards are
highly integrated with video & audio on the motherboard and often Ethernet
and/or modem via a proprietary card... Ben Myers
On Tue, 28 Dec 2004 04:25:21 GMT, "WackoRay" <ray_wacko_foti@NOSPAMhotmail.com>
>be working for now.
>Ray
>of
>replacement
>it to
>& I
>meant.
>> >Ray
>> >> Ray,
>> >are
>> >site for
>> >chipset, that
>come
>> >to
>> >> wrote:
>> >> >Thank You Ben
>> >it's
>> >for
>> >> >it seems.
>> >> >Thanks again
>> >> >Ray
>> >required
>> >> >by
>> >> >> monitor.
>with
>> >> >more
>time...
>> >Ben
>> >> >Myers
>> >> >> >> Hi,
>> >G-6
>> >> >350
>> >monitor
>> >> >will
>> >tried
>> >> >all
>> >work
>> >> >> >only
>> >> >> >> Ray
