Monitor won't come out of sleep mode
lonewolf83
4
Hello, i am running Vista Home & can't use sleep mode as the monitor won't come out of it. What i would like fixed is having the monitor come out of sleep mode, the computer does but the monitor won't, no matter what key you hit or even using the mouse. Is there a fix so i can use sleep mode? I don't like having to leave the computer all the time because i leave windows open that i want to come back to later. Thanks.
weaselman
1,146
43
It has to do with the type of Sleep modes enabled in the bios my friend.
In other words the mode is not set right in one of the bios options/ normal found in the power section of the bios menu. wakeup settings and sleep mode S0,S1, S2, S3, S4
You can do a google of what each mode does.
For example I use S1 and S3 mode. It allows my computer to completely shut down all fans, cut power to all drives, and set the cpu into a very low power state but and keeps the ram powered to hold all current things held in the memory. Even the fan on the PSU is turned off.
One press of the power button brings it back to life faster than a cold boot.
Some boards don`t support all sleep mode functions depends how old the board is most new ones support all four or five modes. In any case you will find a change of the sleep mode in the bios will sort it all out.
Here check the link out on what each of the Sleep modes do in the bios to save you a google
http://gsmblog.com/post/Difference-between-S1-(POS)-and-S3-(STR)-standby-mode-in-BIOS.aspx
Hope it helps you.
Shaun.
lonewolf83
4
Thanks Weaselman, i just scrolled down & seen your answer! Will see if i can understand what this is. I'm not computer literate with the tech stuff.
weaselman
1,146
43
If you get stuck just post and I will run you through it in simple point steps.
Easy as I can make it Lonewolf83 ok. If you take the time to look at the link and the S modes you should get a grasp of it have a good look at the picture in the link at the top of the page then you will know what to look for ok.
crashbanger
11
here are the sleep states again:
6 z
E
tH
The authority on tech
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . Tom's Hardware
Forum
Graphics & Displays
Asus 5850, On startup monitor won't come out of sleep mode
Ø
Asus 5850, On startup monitor won't come out of sleep mode x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
Tags: Graphics Cards r
Sleep Mode r
Asus r
Monitors r
Graphics r
r Edit tags
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
Last response: 12 minutes ago in Graphics & Displays ÕGo to last read post
» Share ò
Limper
June 30, 2012 10:09:46 PM
Limper
I just moved today and when I arrived and setup my comp the monitor just goes into sleep mode and I get nothing on screen. The monitor power button just blinks like it is in sleep mode.
I am using an ASUS 5850 TopCU GPU with an ASUS P6T SE motherboard, 6gig of RAM and a corsair 750 80+ power source. Oh and an I7 920 D0 Stepping CPU. It was working fine less than 12 hours before.
I tried the monitor on another comp and it worked fine. When I unplug the monitor cable it says a cable connection problem. I tried resetting the CMOS on the motherboard and have rotated my RAM to different slots. Also removed the GPU and used the other slot to no avail.
I am thinking the GPU bit the dust but any help would be greatly appreciated.
If the GPU is faulty what would be the best AMD GPU to replace the card? Would it be worth going up to an 7950 or would that bottleneck my system?
Any help would be great.
Thanks
Limper
gMore about : asus 5850 startup monitor sleep mode
Optionsi
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
Ads by Google
Dual Monitor Drivers
Updates Video Drivers for Complete Dual Monitor Support in Windows.
driverfinderpro.com
Limper
June 30, 2012 11:27:02 PM
Limper
Ok I fixed it. I have been up for 17 hours and put in a full day of work than drove 5hrs to a new province. My mind is foggy and I thought I already did this. I took out the power cord and hit the power button 5-6 times. It started fine after this.
Optionsi
crashbanger
12 minutes ago
crashbanger
ACPI state
Description
Working
S0
The system is fully usable. Devices that are not in use can save power by entering a lower power state.
Sleep
S1
S2
S3
The system appears to be off. Power consumption is reduced to one of several levels, depending on how the system is to be used. The lower the level of power consumption, the more time it takes the system to return to the working state.
Hibernation
S4
The system appears to be off. Power consumption is reduced to the lowest level. The system saves the contents of memory to a hibernation file, preserving the state of the operating system, applications, and open documents.
Soft Off
S5
The system appears to be off. Some components remain powered so the computer can wake from input from the keyboard, LAN, or a USB device. The working context can be restored if it is stored on nonvolatile media.
Mechanical Off
G3
The system is completely off and consumes no power. The system returns to the working state only after a full reboot.
The SYSTEM_POWER_STATE enumeration defines values that are used to specify system power states.
MIght be a good time post this info from MICRODO ALL:
The Sleep State
The system enters sleep based on a number of criteria, including user or application activity and preferences that the user sets in the Power Options application in Control Panel. By default, the system uses the lowest-powered sleep state supported by all enabled wake-up devices. For more information about how the system determines when to enter sleep, see System Sleep Criteria.
Optionsi
crashbanger
12 minutes ago
crashbanger
OOPs the formatting did not work too well, did it? Sorry!!
Optionsi
Ask the community
Post an answer
Your answer
Submit your answer
x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . Tom's Hardware
Forum
Graphics & Displays
Related resources:
ForumMonitor won't come out of sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumWindows 7 Sleep Mode Issues/ATI 5800x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumMonitor wont come out of sleep like modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumWeird problem, temps drop after sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumSystem won't come out of sleep mode GA-EX58-Extreme DES Advancedx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumPC won't enter sleep mode (S3)x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumASUS M4A79XTD EVO BSOD coming out of win 7 Sleepx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumCoumpuet will not come out of sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumXP Hanged After Come Out From Sleep Modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumCan't come out of sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumSystem won't boot, monitor in sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumNo display signal coming out of sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumScreen doesn\'t come on after sleep modex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumI7 930 intel m/b that wont come out of sleepx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumMonitor won't wake up from sleep .x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumMonitor goes to sleep mode instantlyx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumNo POST with new video cardx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumCan I upgrade my Asus G73JH to a 7970m?x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
Forum120hz monitor, choosex . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
ForumNeed help with monitor/TV Tunerx . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x . x .
More resources
Ati
GPUs
Graphics Cards
Gtx
HD
Monitors
SLI
Crossfire
Tuner Cards
Radeon
Video
Diamond Multimedia
Matrox
Nvidia
Palit
PowerColor
Asus
Games
Russel Johnson
Praise_Gaben
clutchc
Asus Mars 760 Review: Two GPUs In SLI; One $650 Graphics Card
About Tom's Hardware
Advertising About us Contact Privacy Review product submission Legal
TechMedia Network | Experts
Copyright © 1999-2014 Bestofmedia Group. All Rights Reserved
Ad choices
blkcotton
uninstall your display drivers then restart and let windows find them. worked for me
