monitor wont display anything after reseting bios
Ararbrar
35
My pc was losing connection to my monitor today and eventually after restarting numerous times whenever i boot my pc the monitor doesnt display anything. I did a clear cmos using jumper and removing the battery. The jumper was placed back in the correct place as was the battery. I reconnected one ram stick( i have 2) and my gpu. I also tried connecting my monitor to the motherboard and still no display. I dont know what to do now T_T. ANY HELP IS VERY DEARLY APPRECIATED!
I use a dual monitor setup and both are unable to display anything. I also tried using the integrated graphics with and without the discreet gpu, both times i still have a black screen.
Can you try with another monitor?
It seems to be your motherboard, not your monitor.
Try using the pc without the graphics card (unplugged) , just the VGA integrated. Tell us what happens.
Good luck!
